Tu peux commencé par ça !!
Engine:
MAC cold air induction
Accufab 75mm Throttle Body and Plenum
Magnaflow Xpipes
2.5" MagnaFlow Dual Exhaust System.
Steeda Underdrive Pulleys
Steeda Intake Spacer
SCT 9300 program by Steeda 91 Octane & 94 Octane
Zex kit de base avec 75hp-100hp & 125hp
Bougies Denso Iradium
Gauge Nitrous NV
180 F Thermostat
Drivetrain:
Ford Racing 4:10 gear
Ford Racing Aluminium Driveshaft
Steeda Tri-Ax
Steeda Double-Hook Clutch Quadrant
Steeda FireWall Clutch Adjuster
Steeda Adjustable Clutch Cable
Steeda Billet Aluminium Pedal Covers
Centerforce Dual Friction Clutch
Suspension:
Eibach Spring Pro-Kit
Tokico Illumina Struts & Shocks 5-Way Adjustable
Steering offset rack bushings
Steeda X2-Ball Joint
Steeda Bumpsteer Kit
Steeda Heavy Duty Endlinks
Steeda 4130 Chrome-Moly Alloy Strut tower Brace
Steeda 7075 Aluminium 4-Bolt Caster Camber plates
Steeda Full Length Frame-Connectors & Cross-Braces
Steeda Adjustable Rear Swaybar
Steeda Aluminum Lower Rear Control Arms
Steeda Aluminum Upper Rear Control Arms
Steeda Billet Sway Bar Bracket
Bilstein Heavy Duty Quad Shocks
Steeda 1.375 inch Swaybar
Brake:
Steeda front cobra upgrade kit 2 (555-6011)
Front cobra caliper
Front brembo slotted 13 inch rotor
Front Stainless Steel Brake Line
Rear brembo slotted rotor
SLP Line Lock
Autre:
Corbeau racing seat
Corbeau Harness Belt
Steeda Aluminium door plates
Antenne 14 pouces
Odyssey batterie 15 lbs dans la valise
R2000 front bumper
R2000 Rear Spoiler
Crowl hood
